Eliminating the Throttle Body Heater Plate?
Old Aug 2, 2013 | 11:13 AM
Dan7's Avatar
Default Eliminating the Throttle Body Heater Plate?
Not sure why heating up the air going into the intake is a good idea, but the TBHP is a common failure part, as well as the lines that go to/from it. Anyone see a reason you couldn't snip-snip and connect them by the alternator or something? 1 less thing to worry about.
Old Aug 2, 2013 | 11:20 AM
ralphobell's Avatar
Not recommended in cold weather climates. It keeps your throttle body from freezing and causing your throttle to stick wide open.
Old Aug 2, 2013 | 02:52 PM
Certainly is of no use in south Georgia in the summer. But it is said that ice-up can happen slightly above 32F with right humidity. On the other hand, I can't recall my IAT sensor ever showing temps in that range....
BTW many Mercedes have hot water loop that also goes thru the wind shield washer bottle, so that won't freeze on the Autobahn...
Old Aug 2, 2013 | 03:00 PM
poncePR's Avatar
I by-passed it on my '02 last spring so come winter stay out of my way!!!
Old Aug 2, 2013 | 03:17 PM
Dan7's Avatar
Just don't see the TB getting that cold under the hood. Has anybody even heard (1st hand) of the TB actually freezing?
Old Aug 2, 2013 | 03:31 PM
Maybe they did not live to tell about it.... or it prompted them to buy another vehicle.
Old Aug 2, 2013 | 05:28 PM
Dan7's Avatar
Well, I won't eliminate it now, but when (not "if") this one gives me any crap, I'm bypassing it. I'll just reinstall the original 190F thermostat!
Old Aug 2, 2013 | 07:04 PM
CCRovers's Avatar
It doesn't have anything to do with the temperature of the engine. At part throttle there is a pressure drop as air approaches and passes the butterfly valve in the throttle body. Any pressure drop also causes a temperature drop. That temperature drop along with moist air can cause icing. It can happen well above freezing if the conditions are right.
The MAF uses temperature as a means of determining the mass of air being drawn into the engine. The reading on the scanner is not a good indication of the actual temperature inside the throttle body.
928paul
Aug 27, 2012 12:14 PM
ljdiscovery
Mar 4, 2011 11:10 AM
Daymeon
Sep 10, 2009 01:12 PM
lipadj46
Jun 27, 2009 07:35 PM
Rich 00 DISCO
Jul 3, 2008 09:09 AM
