End All answer to stupid oil questions.
Old Oct 20, 2018 | 11:49 AM
  #261
redwhitekat's Avatar
I use the 3001 and castrol full synthetic oil no issues
Old Oct 21, 2018 | 11:37 AM
  #262
Dave03S's Avatar
No issues that you are aware of anyway.
Old Oct 21, 2018 | 11:55 AM
  #263
CollieRover's Avatar
I’m on to Mobil 301, Castro’s 10w 40 conventional with zddp additive. I love the 15w 40 Rotella, but 10w-40 suits the temps I run in better.
I buy into the synthetic leaks more, and that our engines were designed for conventional, but that is more a feeling than anything. I like changing oil more often vs running synthetic longer. Oil is recyclable, and I like to keep the engine clean.
Old Oct 21, 2018 | 03:54 PM
  #264
I think everyone puts to much brain power into oil. I bet you you could run any oil and get the same results I chose synthetic because it's suppose to not break down under high temps. Our engines run hot
I'm a contractor and have been running Chevy vans forever. Sometimes the oil doesn't get changed for 10-20 k the idle forever always tons of weight in the back stop and go traffic etc. And they run forever
Old Oct 21, 2018 | 06:47 PM
  #265
nathanb's Avatar
There is a whole forum (BITOG) dedicated just to oil-obsessing people, so it's not likely this thread will ever be conclusive. I'm too am skeptical that we have any power to significantly change our experience and results with a single engine just by using different filters, 10W vs 15W, conventional vs synthetic, etc. Those differences are only likely to be statistically significant with large populations such as fleets and with respect to Discovery owners that would be all of them collectively. Despite this rationalization, I could still covet the oil filter relocation kits that let one mount filter(s) remotely. There are universal spin-on versions, but Rimmer Bros. has one that replaces the Rover V8 oil pump cover with NPT take-offs. If it wasn't so costly, I would install that with braided steel lines and AN fittings to a cartridge-type filter, and wouldn't be limited to 3/4"x16 spin-ons. As for bypass pressure and anti-drainback valves, that could all be accomplished independently of the filter cartridges. It's also possible to do HE 3-micron bypass filtering. But all of this would be wasted effort and expense on a tired Rover V8. Maybe someday I'll build something that merits an interest in such things, but anyone with an early Discovery has better things to concern themselves with.
Old Oct 21, 2018 | 07:05 PM
  #266
The Deputy's Avatar
I believe everyone, well not everyone...because l don't, waste to much brain power on oil, filters and such. That was my point when l commented earlier on post #255, just get a good filter, good oil and change it regularly and keep the air filter fresh...and that is plenty. All of this wasted time and energy discussing such nonsense about micro this and micro that, blah, blah, blah...is just plan stupid. After forty years of being a mechanic and going to about five dozen oil/filtration clinics over the years...this all doesn't matter. Just change it (using the manufacturers recommendations), use a good filter...and drive it. If it is going to fail...it's going to fail...regardless. Normally, it's an underlying condition that causes a failure or lack of maintenance...not whether or not you use a 25 micron filter over a 20 micron.
Brian.
Old Oct 21, 2018 | 08:38 PM
  #267
Minus the being a mechanic for as long as I have been on the planet. Oh and Brian's not stupid but admit it you laughed when you saw it
Old Oct 22, 2018 | 01:48 AM
  #268
The Deputy's Avatar
Somedays...l need that...lol.
Old Oct 22, 2018 | 04:03 PM
  #269
Don't we all lol
Old Oct 22, 2018 | 04:45 PM
  #270
Richard Gallant's Avatar
Yes I did
