End All answer to stupid oil questions.
Old Jan 27, 2013 | 11:34 AM
  #161
Originally Posted by ZGPhoto
Damnit Spike, I thought I'd be better off with rotella than the amsoil I had been using. I guess I'll switch back next oil change.
You are better off with the Rotella than the Amsoil for many reasons.
1-your engine wont last any longer with the Amsoil.
2-unless you are going 15-20,000 miles on oil changes you are wasting your money.
3-the Amsoil does not protect better, it just lasts longer.
There are only 2 reasons to use a true full syn lubricant, cold weather lubricity, and service intervals.
Full syn will flow better in sub zero temps and it will last longer.
So unless you live inside the arctic circle or are not planning on changing your motor oil/gear oil/ etc. for a very long time you are wasting your money.
Old Jan 27, 2013 | 11:35 AM
  #162
expedio2005's Avatar
Default An educational read
Hi all, check out Motor Oil 101 - Bob is the Oil Guy
It may change your thoughts on what oil to use. It's a lot of info if you read all of the 'chapters' but very informative.
Old Jan 27, 2013 | 11:53 AM
  #163
Gosh, we've all read BITOG and seen the bias that can sneak in there. Informative, but not always unbiased.
Old Jan 27, 2013 | 12:52 PM
  #164
antichrist's Avatar
One of the most important things for our V8's is higher ZDDP levels for the flat tappets, which many oils had when the Rover V8 was being produced, but have since declined drastically. Rotella T has higher levels. Or at least used to, most of the ZDDP levels I see for it are at least a year old. The most recent number I saw was 1400ppm, and that was a year or so ago IIRC.
There are higher one's out there, but I'm not particularly interested in paying $10/qt.
Old Jan 27, 2013 | 01:10 PM
  #165
Exactly.
Now add to that the ready availability of the motor oil.
I dont want to have to drive across town everytime I need to add oil.
Or if I need more oil while on a trip I dont want to waste time searching for it.
Or order it on-line and have it be back ordered or delayed delivery because of weather.
Old Jan 28, 2013 | 09:54 AM
  #166
British Rhino's Avatar
That somebody questioned this wisdom at all again is almost funny, seeing the title of this particular entry. It works best. The subject line indicates that. I have had it solve the vast majority of the ticking in my 03' Disco, which I had all kinds of issues with. For future readers... Just Do It! No more need for debate on this. Read all the great feedback for these products. And consider the total viability of the source.
Old Jan 28, 2013 | 10:51 AM
  #167
Michael M. Koch's Avatar
I think once a debate such as this gets going, it becomes easy to over-think and over-analyze the minutiae of everything. The important point, of course, is regular maintenance, and there is no component so blessed by the Mighty Rover Gods that it will transform your Discovery into a golden flying chariot. So just go change your oil with whatever your choice of oil & filter may be and get on with it.
Old Jan 28, 2013 | 11:16 AM
  #168
blamo's Avatar
Mine is still bigger ! Lol
Old Jan 28, 2013 | 01:05 PM
  #169
racerxnet's Avatar
Still wasting your time with paper elements. How about surgical stainless mesh filters which are reusable and filter to 35 micron level. Proven and tested in Aerospace, military, Formula 1, and industrial applications where longevity is a must. Costs a bit more, but you **** people will spend more than the initial outlay in the long run. Open, inspect, clean and re-install. DUH....... Logic seems to be lacking sometimes.
Stainless Steel Cleanable and Reusable Oil Filters for your Motorcycle and ATV
MAK
Old Jan 28, 2013 | 01:25 PM
  #170
antichrist's Avatar
There's a reason automobile manufactures switched from element type to spin-on oil filters (though I still have element type filters on my Series Rovers).
Also, a 35 micron particle is 50% larger than what quality spin-on filters will pass.
Add in the fact that it would take me 160,000 miles of driving just to break even on the cost of it and I think I'll pass.
But hey, if you like it, use it.
