Engine Code?
Old Feb 11, 2010 | 03:53 AM
cranky's Avatar
Default Engine Code?
I managed to track down some Magnacore wires over here - Great!
160 AUD - not as bad as what I thought. (140 USD)
But they want:
  • year OK
  • model OK
  • chassis model
  • engine code
I'm guessing the "chassis model" is VIN Number?
I'm at a loss as to the engine code or where to find it.
help!
________
Use I Inhale Iolite Vaporizer Review
Old Feb 11, 2010 | 06:34 AM
Rovin4life's Avatar
make sure you get only lucas rotors, otherwise they will run like crap.
I am assuming the truck is running like crap with all the rain the area has been getting.
Old Feb 11, 2010 | 07:34 AM
hilltoppersx's Avatar
i think the 8mm pt number is 80196 for D1's
Old Feb 11, 2010 | 08:44 AM
okdiscoguy's Avatar
http://www.magnecor.com/magnecor1/files/catalog.pdf
If you have a 94 it is different. I show 80196 as the part number for the 8MM. The part number listed above is for 7MM on a 96 & up distributorless ignition
PS, not sure if they will ship to you, but they are $74 here..
http://www.apexperformance.net/CartGenie/prod-1158.htm
Old Feb 11, 2010 | 11:08 AM
Yes yes.. you are correct. swing and a miss, will edit my post as not to confuse
Old Feb 11, 2010 | 02:25 PM
cranky's Avatar
Not changing the rotor for now.
The truck is running great - compared to recent history! just using enough fuel for two.
The existing leads are cheap & nasty and the plug covers are cracked.
no they won't ship to Australia.
I was just after the info they asked for, I'll let them work out the part number, thanks.
Does anyone know what the engine code is or where I can find it?
________
Class action settlement
bosshogt
Jan 20, 2014 09:29 PM
hatt53
Mar 27, 2013 05:16 PM
pixel
Mar 5, 2012 12:29 PM
sayeedA
Nov 15, 2011 11:02 PM
