engine code, and trans question
Old Oct 29, 2006 | 12:48 PM
eve6er69's Avatar
4th Gear
Default engine code, and trans question
hi
i am new to this site. i have a 97 disco and the check engine light is on. i have a scanner and i think the number is 1193. it is bad fuel air metering, manufacture contol. i tried to replace the gas cap, and it comes on and off once in awhile. for the most part it goes off when i fill the tank. sometimes when i turn the truck on it will or will not come on. kinda like the lottery, lol
one other question. is there a bypass switch to shift the trans out of park if it is stuck into place. i recently couldnt get it out of park and i ripped out the whole center column, come to find out it was the brake light switch and it was that easy. i didnt even need to pull the column apart. u should have seen us trying to get it off the tow truck bed, in park.
so i just wanted to know for future refrence.
Old Oct 29, 2006 | 01:22 PM
Default RE: engine code, and trans question
P1193 Oxygen Sensor Heater Circuit Open Downstream
You are looking in the wrong direction.
How many miles on your truck, what gas have you been running?
Mike
Old Oct 30, 2006 | 10:35 PM
eve6er69's Avatar
4th Gear
been running premium and it has 130,xxx mi.
i am just wondering cause when it was an o2 the scanner said it was an o2 sensor. its just weird the it says bad fuel air metering
Old Oct 31, 2006 | 10:55 AM
At your mileage, your O2's are getting tired, change out the 4 of them and watch how your power and mpg improve.
Mike
Old Oct 31, 2006 | 07:24 PM
eve6er69's Avatar
4th Gear
yeah i know i replaced one about 2 months ago. i just can afford them all, at 140 bucks a piece. lol
abran
Apr 27, 2014 06:59 AM
exhilir
Feb 14, 2014 11:16 AM
Coyote
May 3, 2013 03:41 PM
sayeedA
Nov 15, 2011 11:02 PM
The People Family
Aug 6, 2008 10:32 PM
