Engine cranks in key position II
Old Jul 25, 2017 | 05:53 AM
Mondel's Avatar
Default Engine cranks in key position II
Can somebody please assist me? my LR DISCO II cranks in key position II, electric windows are not working and gear indicator position wrong.
Old Jul 25, 2017 | 08:58 AM
LR03NJ's Avatar
Recently I had problem with my key and wont start the car. I used a contact cleaner, insert the straw inside and sprayed really well until it started to drip.
The problem is the key cylinder. They get worn. All my trucks have a sweet spots to get electrical working. Valet people cant even start it sometimes. One, i had to start it then turn the key back to get the electrical working. 2nd, had to mive key to all direction to start it. 3rd had to pull key 1/8 if inch so it can start.
Old Jul 25, 2017 | 09:50 AM
Best4x4's Avatar
It's most likely the actual electronic switch behind the lock cylinder. It plugs directly into the fuse block under the dash. I grabbed a spare at the pick n pull for 5.00.
jrkstore43
Sep 28, 2012 04:16 PM
texmanmoore
Dec 5, 2010 12:45 PM
jennina1
Aug 15, 2009 09:45 AM
