Engine knock.
Engine knock.
Hi, have a 96 Disco 3.9 with 130ks (not miles). Engine starts knocking once warmed up. Does not knock at start up, idle, runs fine for about 15 mins then starts knocking under acceleration or load. Oil pressure light is fine. Dropped the sump, cleaned the oil pick up. Both pretty clean to start with. Pulled big ends out. Worn down to the copper on upper half, lower half not so bad. Am I on the right track?
