Engine knock.
Old Jul 20, 2009 | 06:02 AM
dogs55's Avatar
Default Engine knock.
Hi, have a 96 Disco 3.9 with 130ks (not miles). Engine starts knocking once warmed up. Does not knock at start up, idle, runs fine for about 15 mins then starts knocking under acceleration or load. Oil pressure light is fine. Dropped the sump, cleaned the oil pick up. Both pretty clean to start with. Pulled big ends out. Worn down to the copper on upper half, lower half not so bad. Am I on the right track?
Old Jul 20, 2009 | 07:05 AM
Well with only 80,000 miles on it I would not think that the bottom end was going bad unless the oil was never changed in this thing.
You already have it apart so go ahead and replace the rod bearings, once that is done and it still knocks we can figure out what is wrong.
"YUP", have you ever replaced a set of bearings before?
Old Jul 21, 2009 | 04:19 PM
dogs55's Avatar
Yep, mostly on the bench, once inside engine bay. Happy to listen to any suggestions though.Thanks
coors
Jan 11, 2013 09:28 PM
gtuplin
Jul 15, 2012 12:18 PM
salve7
Jan 7, 2010 02:34 PM
targotsi
Feb 18, 2009 05:58 PM
stick
Jan 27, 2008 01:29 PM
