Engine noise 2000 disco II
Old May 1, 2015 | 10:48 AM
lndrover@carolina.rr.com's Avatar
Default Engine noise 2000 disco II
I have a 2000 disco II. I am getting a bearing sound from he engine comp. sounds like its coming from something in front by the fans. My dealer had told me about three month ago that a small fan was going bad. And to just wait for it to crap out. He said the part was about 400. Does anyone have a idea what this part or little fan is. Thanks in advance.
J. Ferguson.
Old May 1, 2015 | 10:53 AM
drowssap's Avatar
i'm assuming he means the condenser fan, pretty stupid for them to say wait until it burns up, seeing as it keeps your truck from over heating.
there are thousand of fans on ebay that will fit in there, it does not have to be a LR part.
I install two 12 inch fans side by side that I got off ebay like three years ago cost me like $50.00 total.
Old May 1, 2015 | 10:58 AM
GOOD GOD. These people are amazing. So what would you recommend. Thanks you again for your help. The dealer here is really kind of a mess in the service department. Maybe I should get a independent to do it. Is it hard to do. I am not very mechanical.
J.
Old May 1, 2015 | 11:10 AM
drowssap's Avatar
then ask run a post looking for some one good in NC, their are people on the forum from around there that could suggest a good mechanic.
if you going to use a mechanic, then he will probably just want to replace what there with the same.
check with Paul Grant he probably has a few.
Old May 1, 2015 | 11:24 AM
Just found a fan on eBay looks like new and is warrantied out of a 2004. I ordered it. Is this a simple job i could do myself or more involved.
J. Thanks.
Old May 1, 2015 | 11:25 AM
drowssap's Avatar
its been a while, but I think the hardest part was removing the grill
Old May 1, 2015 | 11:27 AM
It's pretty straight forward to do.
Check out the rave land rover manual it has instructions.
https://landroverforums.com/forum/ge...-images-42972/
marlymarl
May 23, 2011 06:54 PM
Rhino1
23
Oct 28, 2009 07:19 PM
Eulogio
Jan 21, 2008 04:17 PM
procurbusa
Aug 14, 2006 03:19 PM
