Engine Noise
Engine Noise
Hey guys-
One more question tonight!
I also recently had new plugs and wires put in as I am working my way down the major service (I went with the 8mm Magnecor and Bosch plugs).
Immediately afterwards I had some error codes (P0154/P0155) that ended up being the result of a loose MAF sensor and some noise that I have not figured out. I am taking it back to the shop this weekend, but wanted to post a video for some advice. It is loudest from inside the car but is clearly from the engine.
See video here:
Does anyone have an idea what could be causing the repetitive low noise that is most clear at the end of the video?
If it is something major, I would almost rather not know!
Thanks
-Dustin
See video here:
Thanks
-Dustin
That almost sounds like a video a guy posted awhile back of his power steering pump growling. I remember he took a 15mm socket and breaker bar and gently applied pressure to the belt tensioner with the engine running and the noise subsided (but of course returned once the tensioner was released). Be careful (remove viscous fan) not to jump the belt. Have you tried something like that? At least you could narrow the noise done to something on the front cover.
Or you could just take the belt off all together but don't overheat your truck.
Found the video:
Found the video:
Kinda sounds like my alternator did before it went out. Stick a long screwdriver or something to where you think the sound is coming from and hold your ear to the other end, should help you find it better. I carry a 2+ foot long flat head screwdriver with me and it is mainly used for locating the ticks, grindings, and squeaks under the hood. Prolly gets used atleast twice a week. Good luck.
bradman951
04-27-2013 02:18 AM
