engine oil light comes on when braking
Old Mar 30, 2009 | 03:26 PM
jcoreilly's Avatar
4th Gear
Default engine oil light comes on when braking
Hello all, I have an 04 Disco with about 35,000 miles. No major problems so far. Lately, in the past few weeks, the engine oil light comes on when I brake moderately hard to a stop. This doesn't happen all the time, perhaps at one stop every other day. I'm thinking it just needs a top up, but I'm worried it's a symptom of a more serious problem. The engine sounds fine, no rattles.
Old Mar 30, 2009 | 03:34 PM
Go and have your oil pressure tested TODAY!!
Old Mar 30, 2009 | 03:39 PM
jycsalas's Avatar
When was the last time an oil change was performed (what type) and what other maintenance service has it had?
Old Mar 30, 2009 | 04:00 PM
jcoreilly's Avatar
4th Gear
Thanks for all your replies! To clarify, the light turns off immediately after. It had the full oil service about 8 months ago. I intended to take it in soon anyway.
Old Mar 30, 2009 | 04:03 PM
Wait, wait, wait, your last oil change was 8 MONTHS AGO?!
When was the last time that you checked the oil level? How far have you driven since your last oil change?
Old Mar 30, 2009 | 04:15 PM
jcoreilly's Avatar
4th Gear
It's not driven very much - perhaps 4k miles since then. I've been doing it roughly every 5-6k miles, and it has been fine so far through the life of the vehicle, and it's never done this before.
Old Mar 30, 2009 | 04:26 PM
There are a few number of 2004's with bad oil pumps, yours may be one of them.
You really need to change the oil more often, every 3 months or 3,000 miles, if you are using full synthetic motor oil then every 6 months or 5,000 miles, and check the oil level EVERY time you get gas.
Old Mar 31, 2009 | 09:54 AM
Start paying more attenetion to your truck or it will cost you dearly. Oil is changed on our adiscos, every 3000 miles or 6 months with no exception except for using synthetic oil then change every 5000 miles.
Get that pressure checked ASAP.
mtrdrms
Jan 2, 2013 08:35 AM
bigsmokefarmer
Dec 5, 2012 02:40 PM
96SE7Disco
Jun 13, 2012 10:55 AM
marlymarl
Apr 21, 2012 12:49 PM
skyguy
Jul 19, 2011 02:04 PM
