Engine Options
Old May 15, 2017 | 12:29 PM
  #91
CollieRover's Avatar
Originally Posted by Mstudt
Looks like the t-stat is the correct one. Next thing to check is the viscus fan to see if it's working as it should. I may go ahead, and replace the original clutch with a servere duty clutch from Napa.
Have you tested the A/C Fan? It may not be coming on and helping when A/C is running. It could cause high temps.
Also, to make sure, the thermostat is the grey one right?
Old May 15, 2017 | 01:10 PM
  #92
Mstudt's Avatar
The t-stat is the grey one. So unless it's faulty out of the box I'm good there.
The AC fan is something that was on my list to check, and replace if necessary. At what point will the AC fan engage. What is the best way of test that? I assume I should be able to hook it up the 12v, and it should turn on.
Old May 15, 2017 | 02:43 PM
  #93
akrover90's Avatar
Was it a genuine one in the LR box? I've definitely read more than once on here that people have had aftermarket 180 ones that were actually 190.
Old May 15, 2017 | 02:48 PM
  #94
Mstudt's Avatar
It was a Genuine LR in the box.
Old May 15, 2017 | 08:30 PM
  #95
If memory serves, and it probably doesn't, it's 80 degrees for the fan to assist.
you can just replace the motor, I had to go flex a lite due to corrosion of my old fan. Could not reuse it.
Old May 16, 2017 | 06:42 AM
  #96
Mstudt's Avatar
I'm thinking this might be my case as well, but I won't know until I pull it apart tonight. Which Flex-A-Lite did you end up going with?
Old May 16, 2017 | 07:59 AM
  #97
Zonk872's Avatar
I live in Florida where it has been in the low 90's. I have the gray T-stat and replaced the radiator last year. Recently bypassed the t-body plate and changed up my coolant ratio. I ran 50/50 before. Now I run estimated 70/30 distilled/ coolant with Water Wetter and Xerex Oat. My temps:
188- 194F rolling
195- 199F idle at light
50/50 ratio (prior)
194- 199F rolling
194- 210F idle at light
I will change to 50/50 in the Winter.
Not that it will fix your temps just some dialogue... good luck! Sounds like the fans are a good direction. Keep us posted👍🏻
Old May 16, 2017 | 08:15 AM
  #98
Mstudt's Avatar
188- 194F rolling
50/50 ratio (prior)
194- 199F rolling
I'm considering adding Water Wetter at this point. I figure it can only help the situation so why not. If I have to drain the system down the swap out the t-stat again I may also play around with the coolant ratio like you did.
Thank you for this information too!
Old May 16, 2017 | 08:26 AM
  #99
Zonk872's Avatar
With the investment that that you made going that extra step is worth it. Although it tests your sanity... sometimes a good flush helps the vehicle and the psyche 😂🍻.
Old May 16, 2017 | 08:54 AM
  #100
Mstudt's Avatar
Here's a list of the part numbers from Autozone for the items I ordered.
Fan Blade: 620-112
Fan Clutch: 922790
Fan Motor: PM9116
