Engine pinging
Old Nov 6, 2014 | 03:15 PM
ShaggySE7's Avatar
Default Engine pinging
Hi all
My 99 D2 pings a little. Usually when not up to full operating temp. So I baby it until then. No codes ever. Running premium. What sensors could be causing this without throwing a code? I know it could be the knock sensor but could it be O2 sensors? And I do have the correct plugs. Also I don't believe there is any carbon buildup. Thoughts and Ideas please.
Old Nov 6, 2014 | 10:50 PM
jfall's Avatar
Put in premium from a different gas station.
put in octane boost.
If it only pings at warmup - you may actually be hearing the piston slap if you are up over 120,000 miles.
Don't worry about it.
Old Nov 7, 2014 | 07:16 AM
drowssap's Avatar
you might want to check you knock sensors, if your running premium that should not be an issue
Old Nov 7, 2014 | 10:17 AM
Dave03S's Avatar
If a knock sensor is bad you would notice even worse gas mileage along with pinging.
Old Nov 7, 2014 | 10:29 AM
ShaggySE7's Avatar
It is definitely pinging! Also I have been having this problem for quite some time. Many different gas stations. Engine was rebuilt at 87k with top hat liners. Currently I have 113k.
Old Nov 7, 2014 | 10:30 AM
ShaggySE7's Avatar
So there are 2 knock sensors. I will probably just replace them.
Old Nov 7, 2014 | 11:19 AM
Dave03S's Avatar
I don't know how many there are but mine failed because the wire was pinched. The sensor was good, had to replace the entire wire in the harness.
It is a shielded wire so just resoldering or using butt splice connectors does not work.
99Discovery II
Aug 2, 2012 08:23 PM
DiscoHelp
Oct 3, 2011 06:18 PM
ljdiscovery
Jan 12, 2009 04:05 PM
mackshawnd
Apr 24, 2007 01:58 PM
teamyonex
Nov 2, 2005 01:08 PM
