Engine pulling question
Old Dec 8, 2022 | 10:38 AM
Alex_M's Avatar
Nice! Start to finish, roughly how long did it take you to get the set pulled out of curiosity?
Old Dec 9, 2022 | 05:26 AM
Extinct's Avatar
I can have them out in less than 4 hours.
Old Dec 19, 2022 | 08:58 AM
Tony Luna's Avatar
Round 2…
Going to start tearing it down over the holiday break.
Old Dec 19, 2022 | 06:00 PM
XRAD's Avatar
nice pic! is this your top hat block?
Old Dec 20, 2022 | 07:03 PM
Tony Luna's Avatar
Yep - going to see if I can just have the scored up liner replaced. Problem is, I had all the cylinders honed to fit Grade B 4.0 pistons. Now I cannot find a replacement Grade B piston. Maybe I’ll have all liners replaced and start anew with 4.6 pistons.
Old Dec 21, 2022 | 06:13 AM
Extinct's Avatar
What happened to it?
Old Dec 21, 2022 | 01:24 PM
XRAD's Avatar
I thought 4.0 and 4.6 pistons were same diameter(94mm)? maybe different piston CR's and rods...and the stoked crank that's different.....so you could build this into a 4.6.....
and as Extinct asked, "what happened'?
Old Dec 22, 2022 | 07:02 AM
Tony Luna's Avatar
They are. Problem is I had Grade B pistons - slightly larger in diameter.
Not sure yet. Sleeve 6 has some scoring and the HG was blown at the top - blowing into valley. The HG was missing a small piece of the steel ring.
I’ll start a new post and include some pics.
Old Dec 22, 2022 | 09:54 AM
XRAD's Avatar
hmmmm....sounds like the piston was too big...or a ring cracked. did you measure the new bores in the top hats before install? strange about the head gasket....curious as to which head gasket you used...
also, was the damaged head gasket at the same location as the scored cylinder? maybe the piece went into the cylinder...
Sixpack577
Mar 16, 2018 07:29 PM
lilherc
Apr 29, 2013 02:21 PM
Trunk Monkey
Dec 21, 2012 08:36 AM
pedronz
Oct 20, 2011 11:04 PM
BURover
Aug 30, 2006 03:06 PM
