valve clearance adjustment
Old Apr 28, 2013 | 10:10 PM
lilherc's Avatar
Default valve clearance adjustment
Hey guys does anyone have any video links or instuctions on how to do a valve clearance adjustment on our specific motors.
Old Apr 29, 2013 | 12:54 PM
earlyrover's Avatar
Default Valve clearance adjustment
This engine has hydraulic valve lifters; are none adjustable, unlike earlier adjustable valve clearances done on non hydraulic lifter engines. However, it still may be advisable to install and use some sort of clearance adjusting device, as shown by my early experience with this engine, as used in 1970 Rover 3 litre car and other vehicles. Do google search for what you seek, and you will eventually find an old website out of England, whereby Rover engine rebuilders talk about exactly what you ask about.
Old Apr 29, 2013 | 02:21 PM
willrok13's Avatar
Disco mike did a write up a couple years ago describing the rocker arm shim procedure. As earlyrover said, lifter preload is about the only thing you can change. What exactly is your issue?
https://landroverforums.com/forum/di...n-noise-37553/
h1duck
Feb 13, 2014 07:05 PM
Frank4
Jun 17, 2010 09:38 PM
HanselRox
Sep 24, 2008 04:00 PM
freeranger
Mar 29, 2005 06:03 PM
