Engine shudders
Old Mar 1, 2023 | 10:20 AM
miron's Avatar
Default Engine shudders
Hello,
Weird thing is happening to my disco. Whenever I'm stopping on an intersection the engine will start shuddering when in drive. When I switch to neutral it stops. I'm guessing it might have something to do with vacuum lines, but any insight would be welcome.
Thanks
Old Mar 1, 2023 | 01:45 PM
redwhitekat's Avatar
sounds like your transmission or transfer case issue
Old Mar 1, 2023 | 02:14 PM
miron's Avatar
Hmm, the transmission's been doing some weird things lately - i should look into that. Thanks for the hint.
Old Mar 1, 2023 | 02:27 PM
Extinct's Avatar
Yep, sounds like a torque converter going bad. Does it do it accelerating away from a light?
Old Mar 1, 2023 | 02:48 PM
miron's Avatar
Nope, just when idling, but its been having issues downshifting.
Old Mar 2, 2023 | 02:00 PM
Pllamie's Avatar
4th Gear
Default Engine mounts?
I had a similar issue, discovered that both my engine mounts and the right transmission mounts were sheered. I replaced them and that problem stopped. I still get some shudder at highway speeds when maintaining constant speed downhill though . Trying to work that out.
Old Mar 2, 2023 | 03:13 PM
miron's Avatar
The problem with "my" shudder is that it's not constant. It happens every say 30 seconds - just one strong vibration and the rpms drop, so the torque converter scenario seems like it could be the culprit.
Old Mar 2, 2023 | 03:27 PM
Pllamie's Avatar
4th Gear
I wish you luck in finding the cause. Mine was shuddering at a stop and wanting to pull forward until I would put it in neutral. I saw in another thread a similar issue caused by the engine mounts and sure enough, I saw cracks in the rubber on mine and they were completely sheered.
Cheers!
Old Jul 22, 2023 | 02:19 PM
miron's Avatar
Yeah tc just started knocking. Thanks for the pointer!
garthbrooks
Range Rover Classic (1st Gen)
Sep 27, 2019 07:57 AM
Bartlomiej
Jan 3, 2014 08:49 AM
coastie
Dec 24, 2012 04:40 PM
xkelley
Mar 29, 2009 09:03 PM
tads
Jul 6, 2007 04:13 PM
