engine turns off
Old Sep 28, 2009 | 01:34 AM
btbaus's Avatar
Default engine turns off
sometimes, when i start the rover , hot or cold, it will run for about 2 seconds and then turn off. i turn it on again and it runs but kinda sluggish, sorta like its gasping for air. the sluggish-ness goes away after a rev the engine a bit.
i suspect the fuel filter needs replacement. has this happened to anyone before?
113ish miles on the clock. 95disco
Old Sep 28, 2009 | 01:40 AM
sloppyjoe's Avatar
i would venture a guess at a clogged filter. when was it last changed?
Old Sep 28, 2009 | 02:09 AM
btbaus's Avatar
i dunno when it was last changed. the fuel filter will be changed, whether or not this problem is related to the fuel filter. i just wanted to know if someone had run into a problem like this and what resolved it.
Old Sep 28, 2009 | 07:29 AM
Change your filter, this could be your problem and is pretty common.
Since it hasn't been changed for awhile you will need to spray the fittings to remove the filter.
If the problem still happens then you may have a valve in the fuel pump failing which will cause the fuel pressure, in the rail, to bleed of when not running.
Old Sep 28, 2009 | 11:12 AM
You can buy the fuel filter at Wal-Mart for $15.
Old Sep 28, 2009 | 03:17 PM
btbaus's Avatar
thanks guys!
Lord Wert
Jul 4, 2013 07:52 AM
techaniz
Feb 12, 2013 03:40 PM
'BamaBoy
May 24, 2012 12:45 PM
nomar07
Mar 29, 2012 02:29 PM
Gomie
Feb 3, 2009 03:16 PM
