Engine vibrates disco at 2k-3k
Old Apr 27, 2006 | 11:50 AM
Flyboy's Avatar
3rd Gear
Default Engine vibrates disco at 2k-3k
Just picked up a 96 Discovery SD 5sp about a month ago with 89000 miles. Everything was real smooth(acceleration, braking, suspension, shifting). I got my oil changed last week and flushed the engine, the old oil was black. The owner of the lube shop said my tranny, diffs, ball joints, everything looked good. This week, when I accelerate from 2-3k rpm, my whole car vibrates, not violently, but like I was driving on a bumpy road. It only does this in gear and only when I accelerate, whether i'm turning or driving straight. What do you guys think?
Old Apr 27, 2006 | 06:54 PM
Default RE: Engine vibrates disco at 2k-3k
Here is a list os things to look at, not in any special order.
Bad tire
Bar U-Joint
Broken motor mounts
Bad CV joint
Let me know what you find.
Mike
Old Apr 29, 2006 | 09:11 AM
Flyboy's Avatar
3rd Gear
This is what I found so far
The back driveshaft has a couple of gouges on it where it meets up with the U joint
The engine mounts look like they have seen a lot of heat
Next week, I will be bringing the truck back to the dealer and let them take a look.
Old Apr 29, 2006 | 12:19 PM
Let us know what they find.
Mike
Old May 26, 2006 | 08:29 PM
Flyboy's Avatar
3rd Gear
Land Rover found that the rubber bushing connecting the rear drive shaft to the rear diff fell apart. It was replaced, and now I'm back to a smooth ride.
Old May 26, 2006 | 09:31 PM
ORIGINAL: Flyboy
So you lost a rotoflex, ths is not uncommon, I am about to replace mine at 80,000 miles.
Good you are back on the road.
Mike
Eulogio
Jan 21, 2008 04:17 PM
tcbinaflash
Jan 8, 2008 04:23 PM
rodrick smith
Sep 27, 2007 08:59 AM
BURover
Aug 10, 2006 07:17 PM
miishmiish
Mar 8, 2006 12:31 AM
