Error Code - Cylinders 3 & 7 misfiring
Old Jul 16, 2019 | 12:12 PM
MMalcolm's Avatar
4th Gear
Default Error Code - Cylinders 3 & 7 misfiring
Never saw this before. Under OBDII analyzer, my 2001 Disco II is reflecting cylinders 3 & 7 misfiring but the engine is running smoothly with no signs of misfire. I checked 3 & 7 and they're firing. I ran the check because my gas mileage is absolutely horrible and the engine seems to have poor response. The acceleration is not responsive in the context of going uphill and accelerating into overdrive, the response is almost entirely flat with only slow and gradual increase in speed as if the engine has no real power. Has anyone seen an error message similar to this and what else could cause a message like this to appear? What should true average MPG on a 2001 Disco II like this have.
I went through the upper engine in 2012 because of a head gasket leak that caused radiator pressure and blew a hose. New valve springs & valves, new rings, new fuel injectors, naturally new gaskets. Engine fired right up and runs fine. No problems manifested at the time. This latest OBDII message is puzzling. Doesn't seem to match the fact that the engine is running smoothly with no signs of misfire.
Thanks for any insight.
Old Jul 16, 2019 | 01:44 PM
CollieRover's Avatar
It just may be time for Coilpacks, wires and plugs. How old are the ones in the truck?
Old Jul 17, 2019 | 08:22 AM
05TurboS2K's Avatar
Just what was said above. Especially when it's an issue under load as you're describing. This is the classic scenario as you're describing it.
Old Jul 22, 2019 | 02:39 PM
MMalcolm's Avatar
4th Gear
sorry for the delay. We've been out of town. The plugs, wires, distributor cap and rotor are all a couple of years old at most. Not sure about the coil packs. I rebuilt the entire top engine. It runs fine with the exception of poor performance. I'll get into the coil packs and check them out. Thanks for the reply.
Old Jul 22, 2019 | 02:40 PM
MMalcolm's Avatar
4th Gear
Thanks. Looking into the coils now.
Old Jul 22, 2019 | 05:54 PM
Extinct's Avatar
Easy way to tell is swap coils left and right, see if codes move.
SV_Disco02
Oct 9, 2020 03:29 PM
big-boss
May 28, 2018 08:47 PM
jamieb
Jan 20, 2016 08:40 PM
Charlie_V
Jan 27, 2014 11:35 AM
RYANHASADD
Dec 15, 2007 03:37 PM
