everyone with more than 150K on your original LR head gaskets
Old Oct 19, 2014 | 11:15 AM
  #21
drowssap's Avatar
well that will put a quick halt to your plans
I was thing about changing out to allen heads the next time I have to pull mine.
Old Oct 19, 2014 | 02:31 PM
  #22
coors's Avatar
Tell me about it.
That's actually a great idea. I will look into that. We can probably source a bolt from Fastenal or hell even a box store.
Old Oct 19, 2014 | 02:48 PM
  #23
RicketyTick's Avatar
We talking about the valve cover bolts right? I use a 5/16 12 point...perfect fit. You may have one or have more luck finding one. You got a neighbor or friend with tools?
Old Oct 19, 2014 | 09:26 PM
  #24
coors's Avatar
Yeah, those 1/4" drive deep 12 pointers are bitch to find. I tried several Sears hardware stores, Advanced Auto, True Value, Ace Hardware, my neighbor (who is a licensed mechanic, his buddies shop down the street, Jesus and Big Bird. No one had it.
I ordered one online. I'm sure I'll find the one I misplaced the day the new one shows up at the door.
Old Oct 19, 2014 | 09:32 PM
  #25
Originally Posted by coors
Yeah, those 1/4" deep 12 pointers are bitch to find. I tried several Sears hardware stores, Advanced Auto, True Value, Ace Hardware, my neighbor (who is a licensed mechanic, his buddies shop down the street, Jesus and Big Bird. No one had it.
I'm kinda tired right now and probably missing something but, why do you need a deep?
Old Oct 19, 2014 | 09:37 PM
  #26
coors's Avatar
Never thought of using a shallow socket. Still. Noone had the 12pointer in a 1/4" drive.
I highly considering drilling them and using my "easy out" tool. I'm sure they're sittin loose in there anyway.
Old Oct 19, 2014 | 09:43 PM
  #27
oh ok. I just thought it may be easier to find in 5/16. I haven't had to shop for one but, If I happen run across any I guess better grab a handful.
Old Oct 19, 2014 | 10:11 PM
  #28
lordmorpheus's Avatar
Lol, you can at least take the outer bolts off with a combination wrench to make *some* progress...
Old Oct 19, 2014 | 10:20 PM
  #29
I started tearing the motor down on Friday made it all the way down to the valve covers and realized I misplaced my 8mm 12pt. Doh!
Old Radiator is out, old water pump is off, oil pump is off, and timing gears/chain are coming off tomorrow along with the heads, if I can ever track down that elusive 8mm 12pt.
I was thinking since you had it down that far and as loose as those things usually are you could probably grab them with needle nose.... assuming you have the upper intake off already.
I guess if your socket is coming tomorrow no need.
Old Oct 19, 2014 | 11:17 PM
  #30
beastpath's Avatar
230k on 2001 Disco 2 SD. Apparently a small leak has developed in the head gaskets. Unsure as what to do. My worry is that I change the HGs and then the block fails.
