Excess wind noise from driver's side door/window
Old Oct 17, 2011 | 04:12 PM
01d2Jeff's Avatar
Default Excess wind noise from driver's side door/window
On my 01 d2, I'm getting a lot of wind noise from my drivers side window - almost like it's missing some sealing or weather stripping.
Additionally, my window squeaks about 3/4 of the way from the top of the door whole I'm rolling it up. Any ideas what is causing this?
Old Oct 17, 2011 | 04:16 PM
disc oh no's Avatar
I think parts of the window and its associated parts and mechanisms are adjustable I remember this coming up in another thread before. You might try searching for this problem on this forum. I'm not sure what it was under or, if you've tried a search yet but, I'm almost positive it was on this forum... Good Luck!
Old Oct 17, 2011 | 08:52 PM
Rollers in the window regulator frame, and grease of same.
Old Oct 17, 2011 | 09:49 PM
Your door seal is bad or the door needs adjusting.
The window frame is actually bolted to the door, it can be loosened and adjusted to make a better seal and reduce wind noise.
2 or 3 screws, I forget.
Old Oct 18, 2011 | 07:37 AM
01d2Jeff's Avatar
Thanks, Spike. I'll take a look at it.
On a side note....I notice you're from Grand Rapids - I was raised in Montague, and lived in GR for quite a while.....matter of fact, I used to go to Mars Hill. Small world...
Old Oct 18, 2011 | 01:24 PM
DiscoKline's Avatar
I also get the wind noise, but from my pass side window. The frame is adjustable. There are two torx head bolts one on both ends that hold it in place. Loosen, push towards the cab, hold and re-tighten. Seems to work well...
Old Oct 18, 2011 | 08:23 PM
Yes it is.
KlamathMatt
Oct 14, 2014 04:04 AM
devildollnyc
Feb 13, 2014 01:11 PM
bcolins
Nov 1, 2012 08:29 PM
ryant06
Dec 27, 2007 03:29 PM
ollie
Jun 2, 2005 02:42 AM
