Exhaust Manifold Studs
Old Apr 29, 2015 | 10:08 AM
Fast951's Avatar
Default Exhaust Manifold Studs
Does anyone know the size of the studs at the bottom of the exhaust manifold where the collector pipe attaches? There are three studs, I think the attaching nut is 1/2" or 13mm.
Old Apr 29, 2015 | 10:31 AM
Fivespddisco's Avatar
I don't know off the top of my head. If you were planning on running in a bolt instead of using the studs be careful because one of the the holes is enclosed and you cannot run the Bolt all the way through to tighten it down.
If you need the studs we have them there are about $.85 each
Old Apr 29, 2015 | 12:15 PM
Fast951's Avatar
Okay, thanks. Planning to stick with studs - soon as I drill this broken one out. Man, they seem under-sized. I would like to meet one of the engineers of this vehicle... I think a lot of us would.
Old Apr 29, 2015 | 02:35 PM
agreed!
Old Apr 29, 2015 | 03:34 PM
Joe Btfsplik's Avatar
I know none of you seem to have the Td5 in the USA, but I do and guess what! Had to replace the exhaust manifold studs. My indie (independent mechanic) drilled them out and replaced them with bigger ones, drilled the manifold stud holes out to match, and the problem is now permanently sorted out. Parts - about ten bucks. Labor, on the other hand, about a hundred and fifty bucks. Still, not too bad for the potential agony. Not sure if these numbers would apply to each manifold on a V8, might be too pricey.
Old Apr 30, 2015 | 07:09 AM
antichrist's Avatar
The stud threads are M8x1.25
Obviously the nut is M8x1.25 also, not 13mm
I can't remember the length.
To keep the nuts from fusing to the studs over time, when installing the nuts I use Never-Seez on the threads and Nord-Lock washers.
Old Apr 30, 2015 | 08:37 AM
abran's Avatar
I used some 30mm stainless bolts and lock washers. They cinched up nice and tight. Forgot to add anti sieze though.
Old Apr 30, 2015 | 10:18 AM
Fast951's Avatar
Thanks for the specifics on the studs. The 13mm was a reference for the wrench/socket size of the nuts used to attach the collector pipe to the manifold, which I believe to be correct.
Old Apr 30, 2015 | 08:22 PM
antichrist's Avatar
Yeah, an 8mm cap screw or nut will typically be 13mm across the flats.
FLA Rover
Apr 30, 2015 07:20 PM
twaszak
Jul 15, 2012 07:21 PM
hhalimi
Apr 22, 2012 01:40 PM
jimpty
Dec 4, 2011 10:06 AM
raid13
May 13, 2007 12:13 PM
