Extended Warranty
Old Feb 5, 2008 | 02:06 PM
georgetrieste's Avatar
Default Extended Warranty
Does anybody know anything about this extended warranty and company?
(Dealers Alliance Corporation)
It is for 5years or 100,000miles
COVERED COMPONENTS INCLUDE:
ENGINE –
All internally
Lubricated Parts of the engine, including but not limited to: pistons, piston rings, piston pins, crankshaft and main bearings, connecting rods and rod bearings, camshaft bearings, timing chain and timing gears, intake and exhaust valves, valve springs, oil pump, push rods, rocker arms, hydraulic lifters, rocker arm shafts. The Engine Block and Cylinder Heads are also covered (if damaged as a result of a mechanical Failure to an internally Lubricated Part). The water pump is also covered. No other engine parts are included under this Service Contract.
TRANSMISSION / TRANSFERCASE*
All internally
Lubricated Parts of the manual or automatic transmission and transfer case including but not limited to: torque converter, oil pump, drum, planetaries, sun gear, shell, shafts, bearings, shift rails, forks and synchronizers. Damage resulting from failures by related parts or units such as but not limited to: levers, controls, linkages, cables, radiator, coolers, rubber mounts, external oil lines, viscous couplings, drive axles/bearings and electronic components, internal or external, to the engine and transmission are not covered. Note: Differential Failures of any kind are non-eligible for coverage under this Service Contract.
*SURCHARGE APPLIES
. ELIGIBILITY:
All
Covered Vehicle Components must be factory installed by the Vehicle OEM manufacturer. Modifications of any kind to the Vehicle will void this Service Contract. Prior repair or replacement of such Components must have been completed by an ASE Certified Mechanic (documentation will be required). Pre-Existing conditions are not-covered under any circumstances. NO CLAIMS WILL BE PAID WITHOUT PRIOR AUTHORIZATION CLAIMS 1-866-444-1598 Form #AWR-XX-XX-01
2. COVERAGE STIPULATIONS:
Failure
of a Covered Part, which occurs within the first ninety days (90) and 1,000 miles after the Sale Date that appears above will not be covered and will be considered a Pre-Existing condition. Valid proof of repairs will be required in the event a claim is made on this component at a later date. All Vehicles must be in good mechanical working order for this Service Contract to be valid. Oil consumption, worn out or overheated parts or diminished performance is not covered (this is not a performance Service Contract). Failures must be the result of a proven Mechanical Breakdown of a Covered Component. This Service Contract does not apply to diesel engines manufactured ten years (10) prior to the sale date, Vehicles equipped with Rotary engines, Nissan 350Z/300ZX, Mitsubishi 3000 GT, Dodge Stealth, all Porsche models, all BMW, Jaguar or Mercedes Vehicles equipped with 12 cylinder engines, all Vehicles equipped with 10 cylinder engines and/or Acura NSX. Vehicles used in commercial or snow removal applications are excluded. Please call the Administrator for specific clarification on any coverage’s or exclusions.
3. MAINTENANCE REQUIREMENTS:
To obtain the benefits provided under this
Service Contract, it is the responsibility of the Contract Holder to have the engine oil and engine oil filter changed by a licensed service/repair facility every four (4) months or four thousand (4,000) miles, whichever occurs first. In addition, You must maintain all other Covered Components as outlined in the Vehicle owners manual. Note: Proper documentation and verifiable receipts for all maintenance and repairs will be required in the event of a claim, (handwritten receipts will not be accepted).
4. COVERAGES:
[left]This Service Contract is subject to the Terms And Conditions of the attached [b][size=1][font="times new roman"]Vehicle Service App
Old Feb 5, 2008 | 04:14 PM
Default RE: Extended Warranty
First ask your dealer or shop if they will honor it.
2nd, be aware that it won't cover many claims if you modify your truck, lifts, bigger tires, HD bumpers.
How much are they asking for this coverage?
Old Feb 5, 2008 | 04:26 PM
Thanks Mike, They are asking $1595 for it! Seems to be a great price if the local dealer and shop will honor it.
Old Feb 5, 2008 | 05:31 PM
You will need to have the oil changed by ashop AND keep the reciets until the warrenty is over. As well as changed all other fluids and filters by a shop and keep those recipts too. And you cannot EVER go over 4 months or 4,000 miles. So if you only drive 1,000 miles in 4 months you will still have to pay to have it changed.
It will not cover blown head gaskets. If there is a oil leak you will need to get it fixed, covered under warrenty or not otherwise they can say that it was negelect on your part.
They will only cover $3000 for a new engine, last time I checked a Rover engine is over $4000. And that is total, they will only cover $3000 TOTAL for engine repairs.
Any breakdown that occurs in the first 90 days or 1000 miles is not covered.
Diffs are not covered.
No mods of any kind.
Must have ALL PRINTED service records, nothing hand writen. Any abuse/act of God/etc not covered.
In my opinion, save your money. Put $100 into a money market account and make payments to yourself, if something big comes up that you cannot afford take the money out of the money market account.
If you finance the $2000 with the loan it will cost you alot more than that with interest. They have lawyers writing these contracts to protect themselves, it is easy money for them. Not to mention that they will tell you where you can get the repairs done.
If it sounds to good to be true...
Old Feb 6, 2008 | 06:28 AM
Thanks, I'll take your advice and save my money.
markroll
Mar 19, 2008 10:04 PM
VB_Rover
Jan 27, 2007 09:41 PM
jsyonker
Oct 27, 2005 09:02 PM
01greendisco
Oct 5, 2005 01:46 PM
thansaffel
Mar 18, 2005 04:38 AM
