Failed Emmissions
Old May 6, 2015 | 12:24 PM
smokey847's Avatar
Default Failed Emmissions
What a nice preamble to my Disco's problems. It failed emissions today. Evidently they were not able to get the check engine light to activate on the first click of the ignition. They attributed this to a fuse or a bulb. Could someone help me out on ideas? Need to get this thing on the road!
Old May 6, 2015 | 12:42 PM
drowssap's Avatar
codes?
Old May 6, 2015 | 09:06 PM
smokey847's Avatar
Just got home and to the sheet.
As mentioned, it states, "NO MIL AT KEY-ON-ENGINE-OFF MIL COMMANDED ON." This, evidently, is that the bulb/fuse to the check engine light is burnt out.
4 TROUBLE CODES REPORTED;
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0305 Cylinder 5 Misfire Detected
P1171
Please help and advise on how I should proceed. Thanks!
Old May 7, 2015 | 06:44 AM
drowssap's Avatar
so the rejected you because the light does not come on when you turn the key,
un fortunately I believe it is an led and not a bulb.
Old May 7, 2015 | 07:03 AM
mln01's Avatar
Is the truck new to you or have you had it a year or more so that you know it passed inspection previously? If it is new to you it may be that a prior owner disabled that light so that problems wouldn't be apparent. If you've had the truck a while and it passed inspection in a prior year it probably is just the bulb that has burned out. It is a somewhat tedious job to pull apart the instrument cluster and repair it but if you want your truck to pass inspection that's what you will need to do. Hopefully a prior owner did not butcher the instrument cluster components.
Old May 7, 2015 | 07:38 AM
drowssap's Avatar
it wouldnt be unheard of for someone to reach in and break the led, or cover it with black paint or tape to hind the fact that the CEL was on.
Old May 8, 2015 | 06:00 AM
acamato's Avatar
https://landroverforums.com/forum/di...ne-bulb-49400/
Old May 8, 2015 | 08:58 AM
Alex_M's Avatar
Thats for Disco 1. The D1 and D2 clusters are different, with LEDs in the D2 cluster.
Craigmarsha
Freelander
Mar 20, 2013 05:34 PM
bean0714
Jan 22, 2008 08:03 AM
bmebane
Aug 10, 2007 06:17 PM
texaninmass
Feb 5, 2007 11:54 AM
hecareth
Feb 20, 2005 11:31 PM
