Fairly priced coolant to mix with Pride XL-50?
Old Jul 21, 2025 | 05:32 PM
ahaussmann123's Avatar
8th Gear
Default Fairly priced coolant to mix with Pride XL-50?
Hello peeps, my disco 2 has been running pride XL-50 coolant from the previous owner.
https://paulbhardware.com/antifreeze-coolant-orange-50-50-pxl50
Problem is, the disco loses about a quart of coolant every gas tank
or so. These 4 quart coolant jugs are 20 bucks a pop from the gas station, this is adding up quickly.
Any better solutions that will mix with this to keep her topped up? Should I get undiluted coolant and distilled water? Something that might slowly improve the system as I top it off perhaps????
Thanks all!
Old Jul 21, 2025 | 11:36 PM
Harvlr's Avatar
Topping it up like you’re doing is only a very short term solution, really not much more than to get you back home. You need to figure out where the coolant is going and fix it.
Old Jul 22, 2025 | 12:33 AM
Richard Gallant's Avatar
@ahaussmann123 You are losing a ton of coolant, a quart every tank of gas is a significant leak. You need to find to find out where it is going
Old Jul 22, 2025 | 10:15 AM
Abandisco's Avatar
Thats a pretty significant leak. I'd be looking at how to fix it rather than what to top up with. Try to identify where you are losing coolant. Check the radiator end tanks, heater core, cracks in the reservoir, hose clamps, T-pipes etc.
Is there any significant bubbling in the reservoir or is your oil milky or frothy? Is there white smoke coming out of the exhaust? If so you could have a blown head gasket.
Old Jul 22, 2025 | 10:50 AM
8th Gear
So I put in coolant dye, seems to be coming out of the weep hole in the back of the case mostly. I thought it was the water pump maybe but not if it’s leaking from there? I wonder what is there…
no bubbling in radiator, no smoke. I’d be hard pressed if it’s a head gasket. I had a mechanic say the leak was the head gasket, “that’s where it weeps from” - but I don’t believe him he was pushing for a full rebuild he wanted his 5k.
It’s weird because I get no puddles under the car, no smoke in the exhaust, zero contamination in the coolant, but I do lose a significant amount when I drive. Especially on long trips.
im gonna keep topping it up in the meantime, I only drive once or twice a week and she runs great… so any advice on coolant to add would be appreciated along with tips on how to find and fix the leak because consumption has gotten worse 😂😂
lenzda
Aug 24, 2024 07:29 AM
Externet
Apr 26, 2023 08:58 PM
bigugly82
Aug 23, 2007 04:32 PM
bigugly82
Aug 22, 2007 08:04 AM
bonedoc
Mar 21, 2007 10:04 PM
