Fan Rotation after water pump replacement
Old Jun 6, 2016 | 08:17 PM
jomandm's Avatar
Default Fan Rotation after water pump replacement
Hopefully just a quick answer to my question but I recently replaced my 02 Disco water pump and after everything was reinstalled the fan rotates counterclockwise. For some reason I thought the fan rotated clockwise. I am 99% sure I put the belt on correctly. Can someone verify the correct rotation of the fan for me.
Thanks
Josh
Old Jun 6, 2016 | 08:30 PM
Alex_M's Avatar
Not sure on directional rotation, but as long as the flat side of the belt is on the water pump pulley then you're good. If the ribbed side is on the pulley then you put the belt on wrong. That goes for all the pulleys. Flat pulleys get flat side, ribbed pulleys get ribbed side.
Old Jun 6, 2016 | 09:29 PM
number9's Avatar
Fan is reverse or CC rotation.
Old Jun 6, 2016 | 09:45 PM
mln01's Avatar
Look at the blades. With which rotation will they pull air through the radiator?
Old Jun 7, 2016 | 05:29 AM
jomandm's Avatar
Thanks for the help. Not sure why I thought it rotated clockwise. The fan does pull air through the radiator for example if I put a piece of paper between myself and the radiator it is being pulled towards the engine.
Thanks again
GunnerandDeena
May 31, 2017 04:31 PM
JLK
Apr 9, 2015 02:13 PM
Tidalbreathing
Sep 5, 2012 09:46 AM
mwsharb
Mar 12, 2009 07:52 PM
stupid
Jan 20, 2009 10:54 PM
