Fan runs all the time after warm up
Old Jul 3, 2009 | 03:28 PM
But are the electric fans running because your a/c is on?
Old Jul 3, 2009 | 03:33 PM
tastandish's Avatar
No, I havent had to turned the AC on at all
Old Jul 3, 2009 | 03:36 PM
If the fans are running while driving around town on what of these warm days, with the air off, they are doing what they are supposed to be doing, keeping the engine running cool.
Old Jul 3, 2009 | 03:39 PM
Ok, then since you are not using the a/c you really need to check the coolant temp with a scanner, beg, buy, borrow or steal a OBDII scanner that read LIVE DATA, plug it into your OBDII port and while driving kep an eye on the coolant temp, the truck should run around 196-200*F during normal driving, at 210*F the clutch fan should kick in and cool the engine back down to below 200, at 220*F the electric fans will come on to try and prevent overheating.
Your temp gauge will not move until you are WAY to hot.
SO, either you are running to hot or your sending unit to your electric fans is bad.
I am assuming that you have already checked the coolant level.
Also look for my "fan question" thread from a couple of days ago.
jfall
Jan 23, 2013 07:03 PM
starrock
Jan 15, 2011 08:30 AM
specbiker
Aug 10, 2008 03:00 AM
Darover
Aug 28, 2007 03:01 PM
2k2wranglerx
Mar 15, 2006 05:05 PM
