Fan Shroud Fastener Length and Diameter?
Old Aug 18, 2023 | 12:00 AM
chipmc's Avatar
Default Fan Shroud Fastener Length and Diameter?
So over the years I've lost all of my four fan shroud fasteners (the two on top and two down lower). The last one was today so I don't have any to measure. Can someone send me the specs (length and diameter) of the OEM fasteners so I can order replacements? I take the shroud off enough to not want to stick with zip-ties anymore. I know the Land Rover part number is PZM100060, but those sell at Land Rover prices. I've found from an aircraft and motorsports parts supplier (wicksaircraft.com) many fasteners that could work instead but I need dimensions. Apparently these are Southco DZUS Lion quarter-turn studs. Here's the Southco website that gets into the many different types and specs: https://southco.com/en_us_int/search...rter-Turn+Stud
Any help is appreciated!
Chip Mc.
Land Rover fan shroud/radiator cowl fastener, PZM100060
Old Aug 18, 2023 | 06:31 AM
mln01's Avatar
I harvested a couple of these from a boneyard truck to have as spares. I measured one this morning. The shank is 20mm long, and the diameter at its widest point is 6mm.
Here's an alternate Land Rover part number with much better prices - ANR6461. If you google that part number you'll find that Land Rover Cary has them at $2.50 each. You may want to simply check with your local Land Rover dealer.
LR03NJ
Jan 26, 2018 04:34 PM
KingKoopa
May 15, 2017 11:39 PM
Bravhefen
Jan 25, 2015 06:05 PM
Eak69
Apr 6, 2010 04:50 PM
jmt
Jan 14, 2008 05:01 PM
