Hi Guys,
Just got a Nanocom because of fault amber light.
Its saying fault p1000, lambda sensor upstream 154 times signal missing fault is currently present.
any ideas
If you can go by the description, then pre-cat O2 sensor signal missing, lots of times, could be loose connection of the signal wire or wires, or bad sensor. Don't know which side?
Hi JohnZo,
Thanks for the info, I will investigate
