fault codes - any help please
Old Sep 16, 2013 | 06:36 PM
Skyelr3's Avatar
Unhappy fault codes - any help please
2006 LR3 wont start. 1 click only, no crank.
Here are the fault codes that it's showing:
P0851 - Park / Neutral switch input circuit low
U0101 - Lost communication with TCM
any else pulled these codes and truck wouldn't start?
still hoping to fix with minimal labor.
new brake switch, all Land Rover lights, new battery...
Thanks.
Old Sep 16, 2013 | 08:56 PM
The wiring diagrams show a cable from Transmission module and starter realy headed to the P/N terminal of the ECU. The other side of the starter relay coil goes to another spot on the ECU. Believe it is green with orange color wire for the first cable, and blue with red foir second cable. Page 30 of 241 in the wiring diagrams. Free link to downloads in my signature.
Old May 3, 2021 | 08:16 PM
Pria Crow's Avatar
hi, did you end up fixing the issue? i have exact same problem now. thanks
abrahamd
May 7, 2023 05:32 PM
ReubensRover
Jan 27, 2021 05:17 PM
Daniel Morritt
Feb 25, 2019 11:27 AM
abran
Sep 25, 2018 11:09 PM
johnmb
Feb 12, 2012 04:54 PM
