faulty BCM and or IDU??
Old May 28, 2012 | 09:15 AM
jafir's Avatar
If you get the ECM and BCU from the same car, you'll most likely be able to start it. Your remotes won't work and your odometer will blink. Also VIN might not match if they check that kind of thing for emissions where you live.
I have a hawkeye scanner and I was able to turn off the blinking odometer and sync the keys (with help from a person on the forum who was able to get me my codes from land rover) on my 1999. I couldn't care less about the VIN being wrong.
I think sometimes the software in the BCU gets kind of locked up. I went for a few months without my keyless working on my 2003. Then later I went in to change a setting in the BCU (maybe for my fog lamps or something unrelated) and after that my remotes started working again.
Old Feb 18, 2015 | 11:59 AM
hernandez813's Avatar
Default scanner
Do you still have this scanner? And can you use it to wipe a functioning bcu from a 99 disco 2 so I can replace my bad one?
Old Feb 18, 2015 | 10:41 PM
jafir's Avatar
I have a scanner, unfortunately you have to have the computers together to sync everything. I don't have a D2 anymore or I'd say you could send me everything and I'd attempt to sync them up for you.
roverpdx
Dec 13, 2023 01:15 AM
01bluedisco
Apr 26, 2018 04:42 PM
Street Wolf
Sep 28, 2012 12:59 AM
ajh
Apr 6, 2012 10:47 AM
losbadgts
Dec 31, 2008 12:15 AM
