The FINAL WORK, the TRUTH, about Rover key fob programming
Old Nov 12, 2019 | 08:39 AM
  #21
harley181's Avatar
4th Gear
Default HELP! On Programming New Key With The Nanocom
Hi!
Would appreciate any help on programming a spare key for my Disco 2 TD5 Year 2000.
I recently purchased a key off eBay and it came with a tag with 2 sets of barcodes with numbers (15 digits).
I understand that to program a key with the Nanocom, I will need a 6 digit code.
From what I gather thru the forums, the 6 digit code can be found on a sticker at the back of the circuit board. I've opened and checked and it's not there.
Also, as stated by some of the forum members, the 6 digit code is actually the 2nd, 3rd, 4th and so forth digits from the 15 digit code. Fro example, if the 15 digit code was 1234567890ADEFG, then the 6 digit code would be 234567.
Tried using the 6 digit code derived from the 15 digit supplied with the key but no joy. I followed the steps in the "How to program key using Nanocom" video to the letter. Nanocom support staff was of no help!
Any suggestions? Thanks!
Old Nov 12, 2019 | 09:06 AM
  #22
Sandman614's Avatar
Originally Posted by harley181
Hi!
My Valeo key barcodes look like the following. The first string starting with (*N) and ending in (.F) in the middle of the barcodes is the string you need. If you're certain you did it right with Nanocom and that nothing works I would suggest the seller is cheating people. Is it a Valeo key for a Discovery2?
*N2AB7EF2AB7EFF.*
20/05/04 *FFFFFFFFC02C39O* NN
The sticker on the back of my fob circuit board(buttons side) looks like this
2AB7EF
20/05/04
Old Nov 12, 2019 | 09:16 AM
  #23
harley181's Avatar
4th Gear
Thanks for the reply!
I did try with the barcodes provided with the key:
N047442047441FF
The codes I used 047442. Doesn't work. Replaced the 0 (zero) with the letter O. No joy.
Old Nov 12, 2019 | 09:28 AM
  #24
Sandman614's Avatar
N047442047441FF
Maybe a stupid question but does the red light on the fob light when you click a button? dead battery?
Old Nov 12, 2019 | 09:31 AM
  #25
harley181's Avatar
4th Gear
Fob works for sure as the light lit up when the buttons were pressed.
Old Nov 12, 2019 | 10:14 AM
  #26
Sixpack577's Avatar
Is it a 433 or 315 mhz key?
I asked this recently, as both are available, but apparently all U.S D2's are 315 mhz
Old Nov 14, 2019 | 09:36 AM
  #27
harley181's Avatar
4th Gear
Thanks for the reply.
It's a 433 MHz key.
Would it be possible to check what my D2 uses?
Old Nov 14, 2019 | 10:20 AM
  #28
Sixpack577's Avatar
It's a 433 MHz key.
Yes sir
If it's a U.S model truck, then that's the problem.
All U.S trucks use the 315mhz key.
Old Nov 14, 2019 | 06:56 PM
  #29
Discorama's Avatar
Has anyone tried replacing the 315MHz receiver with a 433MHz receiver? 433MHz remotes are much cheaper than 315MHz, so having a bunch of programmed remotes in reserve is very affordable.
DoubleAFL
Sep 14, 2019 11:34 PM
foobar
Jul 4, 2015 11:35 AM
bballjames
Apr 9, 2013 10:51 AM
Pacerlive
Aug 14, 2011 02:13 PM
chad420
Oct 28, 2009 06:39 PM
