Fixing a loose OBDII
Old Jul 27, 2020 | 10:13 AM
Sean Winter's Avatar
Default Fixing a loose OBDII
My Discovery II 2002 has an OBD2 that won't sit in the trim harness anymore. Instead of rewiring a new OBD2 port, what do you think of adding an extender and plugging that into the trim?
If I did wire a new port, what is the cheapest way to get a replacement? All OBD2s are the same I think.
Photo:The OBD below has an extra port for a SAT. 12 bucks on Amazon
Thanks,
Sean
Old Jul 27, 2020 | 10:31 AM
Mine got the back pieces snapped off.
Old Jul 27, 2020 | 12:32 PM
Richard Gallant's Avatar
No reason the extender would not work, it is just an access port
Old Jul 27, 2020 | 04:44 PM
boston4's Avatar
Unless you need it to be fixed for inspection purposes (I've read of inspectors who will just fail a car if they can't plug in the connector with one hand), I'd just leave it loose. I tuck mine behind the trim to the right of the drivers footwell, along the center tunnel - this is convenient, since I can leave my Ultragauge plugged in and run the cord under the drivers floor mat and up the A pillar to where the screen is mounted, on the dash to the left of the cluster above the air vent.
Old Jul 28, 2020 | 12:51 PM
redrover75's Avatar
I put a sheet metal screw on either side. Just between the trim panel and the OBD port, into the space between them. Works like a charm, rock solid.
Old Jul 28, 2020 | 03:53 PM
JUKE179r's Avatar
If I remember correctly some stateside emissions test facilities will fail you for a loose OBD connector.
My Disco 2 failed in Atlanta, Georgia but it was their fault since they had the guy on video tripping over the connected cable and pulled my ODB port out of socket.
Old Jul 29, 2020 | 02:09 PM
Thank you for the replies. I got the cord today from Amazon, 11 bucks. The new port snaps in nicely. I tied the GPS wire to the main cord, and plugged the main part to existing port. Transmits perfectly.
I got failed by the wonderful Illinois Emissions people before. Not happening again.
Thanks
Sean
Old Jul 29, 2020 | 02:11 PM
Final Look.
Sykman
26
Feb 8, 2020 03:07 AM
AZRover
Sep 25, 2019 06:13 PM
Torancis_LR
Dec 28, 2009 05:21 PM
morfa
May 21, 2007 12:04 PM
traffictech870
Feb 21, 2005 02:30 AM
