Flashing M and S green lights on dash????
Old Apr 23, 2015 | 06:39 PM
  #31
cherry punch's Avatar
3rd Gear
Originally Posted by drowssap
if your ecu sees less than 13 volts the transmission goes into safe mode.
yes; start with a fresh charge battery and check your charging system.
also check and clean all the ground cable while you under there, they are another cause.
hopefully it will be that simple
Put a new battery in and it started back up no problem, thanks
Old Jun 30, 2020 | 08:22 PM
  #32
Leland Morley's Avatar
Originally Posted by Disco Mike
Chris, do your self a favor, do not remove your factory cable ends, clean them, tighten them up then go get a free battery/alternator test done at your local auto parts store, get back to us with the voltage with the engine off and at idle, I have seen brand new batteries that fail.
Had same problem played with all other issues talked about instead of going back have this so called new Battery tested which turned out to be problem with dead cell. Don't Believe just because your Battery is new it's good.
Old Jul 1, 2020 | 04:39 AM
  #33
JUKE179r's Avatar
Great work!
Welcome to the forum.
importdave
Sep 25, 2014 10:18 PM
Joe Pundzak
Feb 9, 2013 12:49 PM
Jadreigo
Sep 13, 2012 07:25 PM
vishrb
Jul 7, 2010 08:26 PM
Larry
Aug 22, 2007 02:53 PM
