Flushed out dexcool and now have no temp gauge. Help!
Old May 7, 2011 | 07:09 PM
jaydog101's Avatar
Default Flushed out dexcool and now have no temp gauge. Help!
flushed coolant out today and now the temp gauges has a red light on and the needle is pegged at cold.
Anyone know what I did??
thanks
Old May 7, 2011 | 09:02 PM
You have a air pocket and the temp sender is not immersed in coolant thus no temp reading on the gauge but the temp unit for the ECU is r in coolant and is reading the overheating of the engine.
You need to re-bleed the cooling system.
Old May 8, 2011 | 12:34 AM
jaydog101's Avatar
right again Spike555!!!!!!!! I also hit the cats and found a heat shield that was falling off on the drivers side cat. took it all the way off and it has reduced the knock considerably.
thanks
Old May 8, 2011 | 06:21 AM
You don't want to drive for long without the heat shields, better fix the old ones and reinstall them.
What year is your truck, how many miles on it, where is the bleed screw located and have you ever replaced the t/stat?
Old May 8, 2011 | 08:36 AM
thanks
Glad to her it.
Remember to always KISS when working on cars.
K eep
I t
S imple
S tupid
axelbeteta
Dec 15, 2012 09:32 PM
CANAMDiscovery
Jan 29, 2012 11:44 AM
CANAMDiscovery
Jan 27, 2012 05:32 AM
edmason
Defender
Aug 29, 2011 04:31 PM
collin Barrows
Aug 8, 2011 09:33 PM
