Fog lamp wiring for driving lights?
So it's been a while since I've posted... life has been a little crazy the last few months.
I'm going to be ordering a new bumper here in the next couple weeks, and I have factory fogs in mine now. I would like to use the existing wiring and hook up some driving lights... is it that easy? or do I have to run new wiring?
Are you planning to use the driving lights instead of the fogs or as well as? The fogs are probably 55w each so a total of 110w which means about 9 amps.
Check the fuse rating for the front fogs (see the handbook). If it's 10 amp then you could use up to 110w of driving lights (55w each) and a 20 amp rating would allow you to use double that.
Correct me if I am wrong, but on 04 when fog,s are on if I turn high beam, fog's turn off , is it different In 2000 model? Because if it's same way U won't have driving- lights and high beams on at same time if U want max visibility, ( maybe U can twick the wires so they come on together, but I don't know how.)
The BCU settings can be changed to allow front fog lamps to be illuminated at the same time as the main (high) beams.
I posted some info on this, here - https://landroverforums.com/forum/di...-lights-66143/
jafir (01-09-2015)
