Fog Light Problem
Fog Light Problem
Anyone here ever deal with the fog lights? My new to me 2003 with 84k (and new engine) works well, but the front fog lights don't come on (rear ones work fine).
Wife wants them fixed, so I'm trying. Found a fuse under the hood, but it's ok. I think the switch is getting power, but nothing happens when it's pushed (no little orange light).
I really doubt both of the front ones are burned out, and yes, I tried them with the headlights on. Is there some other fuse? A grounding wire somewhere? I also tried jumping the connector behind the switch, but no dice.
Any help would be appreciated.
Any yes, I realize how extremely minor this is in the DII world...
Thanks!
Thanks!
Strictly speaking, only the parking lights (and not the headlights) have to be on in order for the fog lights to be on, but since that's also true of the rear light you probably already have that part figured out. I would pull the foglight fuse and put a multimeter set to amps in it's place and try and turn the switch on and off to see if you get and change in current. They're probably just dead.
