Fog Light Wiring
Old Aug 4, 2013 | 02:30 PM
jafir's Avatar
Originally Posted by caymandrew
Bummer, everything in place and no go, guess I'll need to get it reprogrammed.. None of the indy shops in my area have one. I need to get my key fob done as well. What are my options? Hawkeye?
If you're considering getting one of your own, I recommend nanocom evo. It does more than hawkeye currently does on D2. I've got both, just because nanocom doesn't support lr3 yet.
If you're looking for someone that has something that will work there are probably more than I can think of: autologic, hawkeye, nanocom, faultmate, rovacom, testbook.
Old Aug 4, 2013 | 04:22 PM
dr. mordo's Avatar
BTW, you could also just bypass all the stock wiring. Probly cheaper than messing with the BCU. Wire the stock switch to activate the relay, and wire the relay to the lights and power. It would look stock.
I'd also troubleshoot the system with a test light or multimeter before I dug into the BCU. A faulty wire or relay seems likely to me. Relays especially tend to fail with disuse. You could try lightly smacking the relay with a screwdriver while someone presses the Fog Lamp switch. That might break it loose.
Old Apr 20, 2018 | 12:02 PM
Disco_Dion17's Avatar
Default Fog Light Brand Recommendations
I'm looking to add some fog lamps to the front bumper. The above info on wiring was very helpful. Wondering if anyone has any brands of fog lights they would suggest. I am looking to go LED. Any suggestions? Thanks!
Old Apr 21, 2018 | 05:21 PM
Twix's Avatar
Rigid if you don't mind spending thousands. I'd just search Amazon for 7" round LED pods, and use whatever looks half decent
abran
Oct 1, 2013 09:09 PM
wrongway1
Sep 14, 2013 10:09 PM
ebg18t
Mar 1, 2012 07:21 PM
Spencerfitch
Sep 10, 2010 09:32 PM
behnam22
Oct 14, 2007 01:25 AM
