fog lights
Old Mar 31, 2014 | 03:41 PM
PaulMc's Avatar
It doesn't have to be a dealer.
If you know anyone with a NanoCom, Hawkeye, Lynx, Faultmate, etc... they can enable the setting in the BCU.
For connectors to connect to the factory fog lamp connectors, so that you can just plug-in your brush guard lamps, there are two types.
If your D2 is a pre-facelift model, you will need these connectors -
AMP Econoseal III 070 2-way female connectors
2 Way Female Econoseal Electrical Wiring Multi Connector - Genuine AMP Product | eBay
If your D2 is a facelift model, you will need these connectors -
H11 sealed 2-way male connectors
2X H8 H9 H11 880 Male Connectors Connector HID Free Ships from USA | eBay
Old Mar 31, 2014 | 03:42 PM
zeroone's Avatar
That is exactly what he is saying. That's interesting. I'm about to add fog lights to the G/F sonata. Completely wired supposedly. Just change the multifunction switch, add fog lamps and turn them on.
Old Mar 31, 2014 | 07:42 PM
velija's Avatar
Ok ok thanks
A buddy of mine has the launch reader I will give that a try will post results
Thanks again all
Old Apr 1, 2014 | 09:48 AM
TripleThreat's Avatar
Paul,
Are you saying that a US Spec 2000 Discovery II can have the BCU reprogrammed to allow the fog lights to be operational with the headlights on High and Low beam?
Old Apr 1, 2014 | 10:50 AM
PaulMc's Avatar
Originally Posted by TripleThreat
Paul,
It's an option on UK spec vehicles - mine is set to allow front fog lights with main beam, as I like to use the front fog lights as foreground/hedge/ditch illumination in the unlit narrow country lanes where I live.
There are also country/market settings in the BCU, which change some of the available options; so, I couldn't say for sure if the option is available on US spec vehicles.
The only way to be certain, would be to use NanoCom, Hawkeye, etc... to interrogate the BCU settings and the available options.
Old Apr 1, 2014 | 12:59 PM
Thanks Paul... I'll check into it. I'd like to be able to do the same thing here with my driving lights...
Old May 6, 2014 | 08:19 PM
velija's Avatar
Thought I should share picked up near Seattle for 5 bills )
Safety devices full rack with clearance for sun roof
Old Sep 21, 2016 | 10:38 AM
dwatterson1's Avatar
I have land rover safari lights. Can they hook up too the fog light wires ?
Snowdog
Apr 7, 2016 01:05 PM
Frank4
Nov 21, 2015 05:47 PM
abran
Oct 1, 2013 09:09 PM
jordamf
Aug 2, 2011 09:04 AM
mikemeyer0
Apr 1, 2005 02:03 PM
