Which Ford Explorer viscous radiator fan fits the D2?
Old May 31, 2025 | 05:20 PM
WaltNYC's Avatar
Does that fan work on a D1?
Old May 31, 2025 | 05:46 PM
JohnZo's Avatar
They sell kits for D1s, but only TDIs. Guessing it would take some modification to the mounting/sealing to fit up to a D1 V8.
Old May 31, 2025 | 07:13 PM
Best4x4's Avatar
Dorman 620-112 is just a good replacement vs the $$$ OEM unit. Fan clutch will come into it's own on the trail or traffic. Off Road I lock it into 2nd gear using Manual Mode and around 2300-2500RPM the HD fan clutch will lock and temps will drop quickly off road. The flowkooler & HD fan clutch should definitely help in slower speed situations or traffic. Once cruising above 30mph the air flow thru the radiator takes #1 spot as the clutch will disengage from full lock.
Old Jun 25, 2025 | 04:56 PM
Tony Luna's Avatar
Originally Posted by Tony Luna
Thanks!
Been running it al day. Haven’t really noticed a difference. Newish radiator, 180 in-line T stat, Koolfow pump. Typically runs between 183 to 190. So far, pretty much the same.
Ordered one of these to push the Explorer fan about an inch closer to the radiator.
Old Jun 28, 2025 | 05:23 PM
Tony Luna's Avatar
I’ll see if this makes a difference.
graym
Oct 1, 2024 05:56 AM
rlcj_racing
Jan 5, 2017 11:52 AM
BoHuang
Dec 5, 2011 08:49 PM
Eak69
Apr 6, 2010 04:50 PM
maddisco
Sep 14, 2009 03:26 PM
