Frame Rust - repairs needed for safety inspection - advice?
You need to move to CT where a DII rejected by Fred Flintstone could be registered as long as it can pass emissions. More and more of the trucks I'm picking up for next to nothing are looking just like what's in those pictures. I bought one from NYS, one from PA and one from MA in the last two months. They all failed safety inspections (something CT doesn't even perform!) due to holes in the frames.
I'd take a flashlight to the top side of the frame rails along the back. They usually split right along the weld and peel back like a banana skin. It's not pretty and repair is not cheap.
i believe rovers north has replacement sections REAR CHASSIS LEG DSCO II RH PLT001, PLT002 - Rovers North - Classic Land Rover Parts
Devon4x4 sells it: http://www.devon4x4.com/forum/2009-o...mart&Itemid=14
Discovery 2 Rear 1/4 Chassis
Comes complete with 600mm legs (LRD200) with joggled ends.
The Crossmember comes attached to (LRD210 (KVB100100)) with rear bumper Brackets (LRD201) Body mounting brackets(LRD202, and exhaust mount (LRD203)
The crossmember has been designed this way for a speedy removal – refit of the old rusty cross member, it will only take two cuts of the existing chassis instead of trying to time consumingly cut your way through the brackets and end up with an ugly patch work weld, the end result saving you time and money in labour
It's crazy, I guess I have the advantage/disadvantage of being in CA.
The cars here don't rust like that so I never get discos for cheap based on rust(disadvantage)
But, when I pull a car apart I don't saw and drill out every nut and bolt.(advantage)
I parted out a car from Utah and what little rust it had fought me the whole way while taking apart the suspension, driveshafts, etc.
Thanks for all the advice and thoughts guys!
Does anyone have a custom fabricated replacement for that rear end section? If you do, I'd love to have some photos or designs or input!
Thanks!
Thanks!
This looks like a decent alternative: Land Rover Discovery 2 / TD5 Rear Chassis Repair kit. Here's a thread on another repair: https://landroverforums.com/forum/di...chassis-64559/
Hmmm, don't look good collector87. Looks like a bad dose of road salt corrosion. Looks like in some places it's rotted from the inside out.
Whatever the repairs one has to ask is it worth it or economically viable. The other option if you have access to a vehicle lift, the time, enthusiasm and the rest of the truck is good is to swap out the frame for a new galvanised chassis. Big job but doable. Or the final option is to dismantle it and sell the pieces as you'll probably make good money.
See Some Chaps Change A Land Rover Discovery Chassis in 4 Minutes - ClickMechanic
cogsley
Aug 13, 2014 03:24 PM
