Front door hinge
I’ve noticed sag in my driver front door-
im getting contact at top right corner of window frame to B pillar..
Looks like the “door side” of the hinge has holes where it receives the frame side pins.. and they have worn slightly open over time & that’s where the sag is coming from.
Curious is if replacement hinges are a common fix? Anyone else running into this?
benggt (11-07-2021)
I had a mechanic's idiot helper pulling himself up into the truck with his full weight on the door. Made mine sag. I did everything I could with trying to get shims in and trying to adjust... so hard to get at. I think it would be easy if the fender came off. Otherwise impossible to get at the adjustment bolts (as I remember it, was a few years back). I think I ended up just bending it as best I could.
meat
12-08-2015 02:41 PM
