Front door hinge
Old Jan 2, 2020 | 03:56 PM
SundayFunday's Avatar
Default Front door hinge
I’ve noticed sag in my driver front door-
im getting contact at top right corner of window frame to B pillar..
Looks like the “door side” of the hinge has holes where it receives the frame side pins.. and they have worn slightly open over time & that’s where the sag is coming from.
Curious is if replacement hinges are a common fix? Anyone else running into this?
Old Apr 5, 2020 | 05:47 PM
zski128's Avatar
I have run into this. I haven’t fixed yet put I would think a donor hinge should work. Haven’t confirmed this but it appears the 2nd row door hinges are the same just installed in reverse.
Old Apr 5, 2020 | 08:11 PM
I was aiming for reference.
I learned left side doors; front & rear both interchangeable.
I also drilled out pins & replaced with stainless nut/bolt - has worked perfectly.
Old Apr 5, 2020 | 10:48 PM
Fallstaff's Avatar
I had a mechanic's idiot helper pulling himself up into the truck with his full weight on the door. Made mine sag. I did everything I could with trying to get shims in and trying to adjust... so hard to get at. I think it would be easy if the fender came off. Otherwise impossible to get at the adjustment bolts (as I remember it, was a few years back). I think I ended up just bending it as best I could.
Old Apr 6, 2020 | 06:41 AM
JUKE179r's Avatar
My next door neighbor who is obese does this when I would take him to the local market. Irritates the crap out of me.
~rant over~
jimvw57
Oct 8, 2017 06:13 PM
devildollnyc
Feb 13, 2014 01:11 PM
hallfleming
Jul 29, 2011 05:14 PM
sharp
Mar 3, 2009 07:44 PM
