Front drive shaft bolts
Old Aug 22, 2013 | 12:07 PM
Celto 4's Avatar
Default Front drive shaft bolts
Hi everyone ill be installing a new front shaft tomorrow Can I reuse the bolts?if not does anyone know the size and grade?thanks again
Old Aug 22, 2013 | 12:11 PM
dusty1's Avatar
i did not reuse. not sure on size, someone will chime in. but original are grade 5. I used grade 8 for replacement
Old Aug 22, 2013 | 12:13 PM
drowssap's Avatar
you can reuse the bolts but not the nuts, they nuts are nylocks and are made for a single use
Old Aug 22, 2013 | 03:23 PM
Celto 4's Avatar
Thanks
Old Aug 22, 2013 | 07:43 PM
Fivespddisco's Avatar
You should get new nuts and they are specific to that bolt. If you need them we have them and relatively cheap. All that said in a pinch I would not hesitate to reuse the nut until you got new ones.
DiscoJon
Jul 14, 2019 01:51 PM
stb616
Nov 18, 2014 10:01 PM
marshman442
Oct 4, 2011 06:45 AM
reddevildemo
Jul 1, 2009 01:21 PM
mcvickoffroad
Mar 6, 2009 09:02 AM
