Front drive shaft replacement
Old Oct 21, 2014 | 08:44 PM
Mrgeorge's Avatar
Default Front drive shaft replacement
What should the labor cost be to replace the front drive shaft on a 2004 SE II by a reputable garage?
Old Oct 21, 2014 | 08:49 PM
dusty1's Avatar
It's 8 bolts and nuts
20 minutes
Be sure they replace nylocks
Old Oct 21, 2014 | 09:00 PM
Mrgeorge's Avatar
20 minutes
Thank you sir, I see you are in Dallas, I am out in Rockwall and my daughter , who will be off to collage next year loves Land Rovers. So we found one for her and want to be sure it properly maintained . With that sayed do you know of a good place we might take it to that is honest and will do a good job?
Thanks, George
Old Oct 21, 2014 | 09:14 PM
dusty1's Avatar
There is a euro shop in Lakewood (name escapes me, I will look when I get off this airplane and get to my computer)
And good folks at north Texas British (off of 35 up near 635)
Old Oct 21, 2014 | 09:21 PM
I'd do it as a Father Daughter project. You only need a 9/16th and 14mm box end wrench and 45 minutes if your new to swapping a drive shaft. It is as dead simple as dusty said.
That said a shop will probably charge you 1 hour at the shop hourly rate.
Old Oct 21, 2014 | 10:15 PM
Colorado David's Avatar
If you take it to a shop, it will be on the lift for less than 20 minutes. But the book says an hour so they will charge you $100. It's not as much fun to lay on the garage floor, but it will still take about half an hour.
DiscoJon
Jul 14, 2019 01:51 PM
GreenKnight008
Nov 3, 2011 07:19 AM
TripleThreat
Apr 12, 2011 08:58 AM
AZDISCO
Jun 15, 2008 08:11 PM
aublec22
Feb 6, 2008 01:29 PM
