Front Driveshaft Question...
Hey guys, I checked my front driveshaft on my 98 to see about changing the U-joints. Mine already has zerks, and, curiously, it doesn't have the double-cardin joint. I wasa under the impresson they did for98. Is that the case, or do you suspect it's a different driveshaft?
Thanks,
Mark G
Thanks,
Mark G
RE: Front Driveshaft Question...
They changed to the double cardan in mid 99 with the intro of the D2. Yours should be ok if they have been serviced. I was approaching the 150 mark and had no idea on the service, so I had both shafts done for a little over $150. You shouls have 4 u-joints total and no rotoflex on the rear shaft...
robert.juric
11-03-2022 06:08 PM
clandrovers
10-10-2010 01:09 PM
lipadj46
05-31-2009 05:44 PM
