Front Driveshaft Rebuild Complete, double guessing my work.
So I just rebuilt my front driveshaft using Neapco 1-0005 greasable U-joints and Neapco 7-0081NG center ball kit (What a bear to put back together). The U-joint connecting the double cardon to the transfer case flange was the most difficult, particularly the trunions that go into the transfer case flange. The last and final C-clip did not want to fit in. It finally did, however, I can tell that there is quite a bit of pressure on the c-clips on both sides. Now while I don't think that the u-joints are binding, it definitly moves more easily in one direction than the other. Before I install my driveshaft i was wondering- Is it typical for the u-joint connections to occasionally be stiffer on one side than the other? I think the needle bearings are all in place (I took it apart to make sure). If a needle bearing fell in to the bottom of the trunion cap, would the C-clips fit at all? Maybe I am just paranoid, but it is my first time installing U-joints. Thanks
SkymonkeyONE
05-08-2013 12:29 PM
roverbob
01-16-2013 03:04 PM
CANAMDiscovery
12-19-2012 09:40 AM
outdoor7or24
04-02-2012 01:29 PM
