Front Driveshaft Rebuild Complete, double guessing my work.
Old Feb 18, 2009 | 11:27 AM
nynole's Avatar
Question Front Driveshaft Rebuild Complete, double guessing my work.
So I just rebuilt my front driveshaft using Neapco 1-0005 greasable U-joints and Neapco 7-0081NG center ball kit (What a bear to put back together). The U-joint connecting the double cardon to the transfer case flange was the most difficult, particularly the trunions that go into the transfer case flange. The last and final C-clip did not want to fit in. It finally did, however, I can tell that there is quite a bit of pressure on the c-clips on both sides. Now while I don't think that the u-joints are binding, it definitly moves more easily in one direction than the other. Before I install my driveshaft i was wondering- Is it typical for the u-joint connections to occasionally be stiffer on one side than the other? I think the needle bearings are all in place (I took it apart to make sure). If a needle bearing fell in to the bottom of the trunion cap, would the C-clips fit at all? Maybe I am just paranoid, but it is my first time installing U-joints. Thanks
Old Feb 18, 2009 | 12:00 PM
Have you greased the new u-joints, might try adding just a little and see if it frees up. I doubt a needle fell into the cup, may just need to be useda little.
Old Feb 18, 2009 | 12:42 PM
nynole's Avatar
I greased it up pretty well. its just that it moves side to side one direction under its own wieght and in order to move it side to side in the other direction, I have to push it with my hand.
Old Feb 18, 2009 | 08:32 PM
PalmettoDisco's Avatar
The needle bearings are about the same thickness as the clip. If the clips are able to seat at all then the the cap should be free of any fallen bearings, and you should be fine and good to go.
SkymonkeyONE
May 8, 2013 12:29 PM
roverbob
Jan 16, 2013 03:04 PM
CANAMDiscovery
Dec 19, 2012 09:40 AM
outdoor7or24
Apr 2, 2012 01:29 PM
asikuy
Oct 19, 2010 12:12 AM
