Front Driveshaft & Rotoflex Coupling: With Pictures!!
Old Aug 11, 2016 | 05:07 AM
  #21
dr. mordo's Avatar
So - I don't know the answer to your question. I haven't heard of a rotoflex completely failing, no matter the condition.
That said, after breaking down on the interstate a few times, I'm a big believer in preventative maintenance. The last thing I would want is the rotoflex falling apart while I'm travelling because unless I brought a spare or broke in a big city, I know there probly won't be one available for a few days.
And like I said, despite being a huge cheapskate, based on my previous experience I wouldn't run an aftermarket rotoflex.
Old Aug 11, 2016 | 08:36 PM
  #22
shanechevelle's Avatar
Put your truck on an extreme incline and bleed it.
Let it run, heat on.
Squeeze as much coolant in it that it will take, and hopefully youll get all the air out.
Old Sep 3, 2016 | 09:21 PM
  #23
FloridaRover's Avatar
With the installation of the "Tropical Thermostat" I have managed to bring the running temps down into the low 180's, even reaching 179 occasionally while coasting! Over 30 degrees difference!!!
Flushed the radiator and cleared out Walgreen's supply of Peak Global
Still with no AC Fan it will reach 195 while sitting in traffic with the AC running - I have a replacement fan on order
Old Sep 6, 2016 | 07:27 PM
  #24
Went to tackle the driveshaft anddd... not happening
Bolts are on hella tight and I didn't purchase the driveshaft tool so I cannot reach them properly;
Lucky8 Propshaft nut tool ? Lucky 8 Parts and Accesories for Land Rovers
Is this a reasonable undertaking with regular tools & the specialty wrench, or best left to the shop?
Can anyone chime in on their experience replacing this and/or the rotoflex?
Old Sep 6, 2016 | 09:28 PM
  #25
Bom2oo2's Avatar
I replaced a driveshaft a week ago, it's pretty easy job, but hard on my back,! (cause I am getting old), just lift one front tire a little so you can rotate the shaft by turning the wheel, put transmission in N & T-case in neutral also, all I needed was a good socket & short extension for back side, (if too tight use a breaker bar on socket wrench to loosen bolts, for front side of shaft you also need a wrench to hold the bolt,,
I have replaced rotoflex like a year ago, pretty easy , again raise a back wheel & same process, but you will need a socket & a wrench to hold the bolt, when taking out rotoflex take a picture & pay attention to put new one exactly same way, there are little arrow's on rotoflex that show the direction of bolts & where to connect,( it's easy to put them in wrong way),,,
(As for that tool you mentioned, I have no idea what is it for , a simple socket & wrench will do the job,)
Old Sep 7, 2016 | 06:07 AM
  #26
Fallstaff's Avatar
Mine were super tight too.
I chickened out when I pictured myself with one end of the driveshaft detached and the other end held on with stripped and seized bolts.
And then the shop had a hard time with it. I was glad it wasn't me laying under it but some young bucks with better tools and a lift.
8 bolts should be pretty cheap from any shop.
Old Sep 7, 2016 | 07:38 AM
  #27
That is exactly the image I have in my head... plus the fact that the nuts are already worn thanks to Landrover Palm Beach replacing the driveshaft once before, somewhere around 50k under warranty
Old Sep 7, 2016 | 08:55 AM
  #28
Alex_M's Avatar
<p>I had the same issue. Turned out to be both tie rods. I replaced them an realigned with 1/8" toe out using a tape measure and she's been perfect since up to 90, at which point I thin any lifted D2 would get sketchy.</p><p><br></p><p>
Originally Posted by dr. mordo
I'd start with fixing the known issues with the driveshafts. If the vibration doesn't stop, then consider a mechanic.<br> <br> I've had a vibration in the front end at ~75 for years now despite trying multiple driveshafts, new tires, a new (used) differential and replacing one hub.<br> <br> BTW, I tried the cheapo aftermarket rotoflex and it lasted less than a year in moderate usage. Definitely a POS.
<br> <br> </p>
Old Sep 9, 2016 | 02:22 PM
  #29
With the installation of the Lucky 8 driveshaft and Rotoflex Coupling I am once again vibration free!!!
I had my local LR shop install the parts: C&H Auto Services - Winter Park, Florida
She now feels like a luxury vehicle again, I even found a nice LR4 trying to make friends in the parking lot at lunch
Paul Grant
Oct 25, 2013 11:41 AM
Torancis_LR
May 16, 2012 08:29 PM
DooFlotchy
Dec 4, 2011 05:09 AM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
mellyagaunce
Sep 30, 2008 10:26 PM
