Front DS hits sway bar at full droop, Normal?
Old Jun 12, 2010 | 08:15 AM
green machine's Avatar
Default Front DS hits sway bar at full droop, Normal?
Well, getting ready for the 245/75/16's on the D1 and I raised her up 2". To get the front springs in I had to remove the swaybar to get the right side to droop enough due to the front drive shaft hitting the sway bar. It's all back together but I checked full droop of the suspension and the drive shaft contacts the swaybar at full shock travel.... . Do I need to lower the sway bar mounts? Not a big job, but I never saw mention of it on any other posts or write-ups on line.
Attached Thumbnails Front DS hits sway bar at full droop, Normal?-img172.jpg
Old Jun 12, 2010 | 08:40 AM
kenk's Avatar
No, not normal. How's the brake lines, they long enough?
It say's for a defender, but works on disco's also:
http://www.toddcosuspensions.com/swaybardropkit1.html
Old Jun 12, 2010 | 09:12 AM
Brake lines are taught at full droop but not over stressed. The old springs are black and have a blue stripe on them. By ride height I would think they were stock...
Old Jun 12, 2010 | 09:22 AM
Long Haul's Avatar
I made my own drop brackets out of 2"x2" square tubing about 8" long. Yeah my DS rubbed once i lifted it
Old Jun 12, 2010 | 09:46 AM
Thanks. I see you have a 4" lift... I only went 2"..... I had similar thoughts of using a 6" piece and boxing the ends.
Old Jun 12, 2010 | 09:52 AM
Replace those warn out brake lines before they do fail, cause they will.
Old Jun 13, 2010 | 08:20 AM
Thanks... I've seen ones that looked like new on the outside collapse on the inside locking the caliper. I just had a steel line go on my K2500 last month. It failed at one of the clips on the frame rail. Luckily it did it in a parking lot so I had my wife grab my bender and flare tool. The ones on the Disco are recent (~3 mos). Do they make longer softies for the Disco or do I need to bend some steel lines and move the junction to get more slack?
Old Jun 13, 2010 | 08:41 AM
Long Haul's Avatar
Lucky8 has longer brake hoses in stock and atlantic british sells them also. I can tell you the ones lucky8 have are about 6"s longer than stock so theres plenty of room for travel. You can also move the hard line to give you more slack if needed.
deer4011
Jan 12, 2021 07:10 AM
BD_LR4
Sep 5, 2012 10:51 PM
wildstylz
Jan 24, 2011 04:04 AM
Speed racer
Nov 11, 2009 09:44 AM
RoverRover1
Jun 25, 2009 03:10 PM
